Old 04-28-2014, 11:57 AM   #70
Gro Harlem
Member#: 165782
2015 WRX Limitd Stg2
'02 Stg4 & JSW TDI Stg2
OMGHi2U
Originally Posted by gargleblaster View Post
Rally Sport Direct has already confirmed that the 2015 STI rear bars are compatible with previous gen sedan bars. I would imagine the WRX will be the same.
edit: link to proof:
http://www.iwsti.com/forums/3979763-post16.html
Originally Posted by ECP View Post
Havent seen this around the forum yet but before you go taking things apart under the hood like the thread here http://www.iwsti.com/forums/2015-sti...ng-lights.html
about this topic, just lay down on the ground under the passenger side front under the headlight assembly, look underneath and remove all of the plastic clips holding the mud deflector it's only like 7 of them and 1 10mm bolt, push up through the bottom and right next to the horn, attached to the support brace that holds the horn is the DRL resistor.
Just seperate the connector, wrap it in tape or plastic if you want and align the deflector back in place and clip and bolt it back together. 15 mins tops to do this
No need for a lift or ramps, its that simple
Awesome info! I added it to the knowledge base. I'll be disconnecting my resistor immediately when I get my car...WHICH IS AT 4PM TODAY can't wait!!!
UPDATE: Also Added Stereo/Speaker information but need confirmatoin on the nav unit. Apparently the BRZ had two different types of nav units and I'm not sure which one they are putting in the 2015 WRX/STI's, anyone remove theirs yet to confirm? The wiring kits are different is why I'm asking.
Also I need to figure out if the wiring adapters to get steering wheel controls work from the 2014 Impreza/Crosstek's for both the base and nav head units.
Going to add speaker adapter info when I have someone confirm whether the ones from the GD/GR's are the same, and still need to find out speaker depth limits.
Gro Harlem is offline   Reply With Quote
