Old 06-26-2002, 11:35 PM   #13
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
i have no grudges against you, i just want to state my side
there are two reasons why/how my shift kit is "notchier"
one is the bushings. they are quite a bit harder than the OE ones 75A VS.95A
Second if the center piviot is tightened too much and was not greased before instalation it will be very stiff to shift.
With the OE setup this is allready done for the end user. it is just a PNP setup.
also if the tang on the shifter bushings is installed backwards it will bind and make it REALLY stiff to shift.
hope that helps.
[email protected]
Our shifter dosent kill trannys... 400HP will TRUST ME
tom@kartboy is offline   Reply With Quote
