Old 12-18-2008, 03:22 PM   #12
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
There is a fuel line that leaks on the passenger side. its the fuel line that is under the turbo coolant resivour between the 2 intake manifold runners and back a little bit, i just had to fix it on my friends 02 wrx. I had to pull the manifold off and ended up finding a cracked hose on one and also a loose clamp. so i replaced the hose and all the clamps on the fuel rails. took me aboue 1.5-2 hrs.
Im assuming this is the same problem as yours because its a common problem. There is a thread somewhere called "Raw fuel smell log" most everybody has the same problem. But i see you have already found it.
bhhamblin is offline   Reply With Quote
