Old 11-16-2019, 08:50 PM   #4
scriptkiddy
Member#: 503595
So, I found the correct OEM part number for the front axles.
2002 WRX Wagon 5MT front axle part number: 28321FE082
On a side note, was trying to replace my front control arms and wheel bearings today and found out that my front driver's side axle is fused stuck in the hub. Tried using a hub puller, but it didn't budge even a little bit.
So, almost definitely going to need new axles now. OEM are $420 each. That's insane! I found the same part on https://www.subaruparts.com/oem-part...bly-28321fe082 for less, but I'm not sure how reputable that seller is.
scriptkiddy is offline   Reply With Quote
