Old 12-02-2019, 12:03 AM   #8
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid 6MT Swapped WRB
Itís oil blow by on that wet tube
Every hose in your bay started life as nice rubber now itís brittle and should all be overhauled
As far as the smoke check valve cover gaskets and the turbo drain aswell as the power steering pipes that lead to the rack from the pump they can leak at multiple connections some of which cause it to simply just need replaced
Valarius Starchaser is offline   Reply With Quote
