Old 09-27-2013, 02:00 PM   #286
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by manitou View Post
Insulate the outside walls and install a vapor barrier. There are more options than just osb and drywall, I would research it a bit more and make sure the wall covering will work for you needs. Drywall is cheap just not very versatile.
If I can get the electrical done soon, I would still like to try and get insulation and walls up before winter.
I have looked up a lot of different options online and those are the two that seem the most common and "best". I don't think I need much versatility from the walls. If there's an even cheaper option I would be all for it.
