Originally Posted by peekeesh
So i finished installing this kit. I flashed the map, start the car and then the check engine light came on. I checked the code in AP it says... ETHANOL SENSOR VOLTAGE LOW INPUT.
Can someone point me to the right direction?
Don't start the car until you have checked and made sure you are getting a reading by turning the ignition on and monitoring TGV voltage or Ethanol Raw.
