Old 04-05-2016, 11:30 AM   #1
awdtuning.com
Vendor Sales Rating: (59)
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
Default OEM & Amsoil Performance Service Available
For those of you who don't know, in addition to installation, repair, engine building and tuning services we also offer maintenance. We have always provided factory-like service; however we are Amsoil dealers and carry their products in house. This makes taking the best care of your vehicle even more convenient!
Below is a list of typical maintenance schedules along with standard and performance service packages.
Note: that every car has various maintenance requirements due to use, mileage, and wear of components from abuse. Oil is typically changed in smaller intervals, but often is needed around the same time other maintenance is performed. If there are some items not needed or additional items needed at the time of service please let us know in advance.
Subaru Scheduled Maintenance Packages
Every 30,000 miles:
Oil Change Service AMSOIL SAE 10W-40 Synthetic Premium Protection Motor Oil / WIX High Performance Filter
Spark Plugs NGK One-Step Colder plugs
Transmission / Differential Fluid Change Amsoil 75w90
Brake and Clutch Fluid Flush Amsoil DOT 4 Brake Fluid
Coolant flush
Detailed Inspection of:
Tires/Rotation
Timing and Drive Belts
Coolant and Hoses
Fuel System
Brake Pads and Rotors
Steering and Suspension Components
CV Joints, Axles, Half Shafts, Bearings
Total cost $755*
Every 60,000 miles:
Spark Plugs NGK plugs choice
Coolant flush
Replace accessory belts AC, Power steering/Alternator
Replace Upper and Lower radiator hoses
Tires/Rotation
Timing Belt
Fuel System
Total cost $955*
*Cost may be reduced depending on extent of service desired.
Every 90,000 miles:
Transmission / Differential Fluid Change Amsoil or Redline 75w90
Brake and Clutch Fluid Flush DOT 4 Brake Fluid
Coolant flush
Replace Timing Belt and Tensioner and Water Pump
Tires/Rotation
Timing Belt related components such as water pump, idler pulleys, cam seals, etc.
Fuel System
Total cost $1675*
Give us a call at 469-277-3001 to schedule an appt!
awdtuning.com is offline   Reply With Quote
