Old 02-19-2012, 05:32 PM   #1
<<M>>
Member#: 123884
Question EJ22 cam pulley removal to replace seals???
Hi, I trying to replacing both cam seals while I replace my timing belt, I've checked through the forums and have come across much info on removing the crank pulley using special methods,
but how do I remove the cam pulley's, do I loosen these pulleys with the timing belt on -- then won't the cams move out of position, and if so, how do I realign them if the pulleys with timing marks are now off..
If anyone has a walkthrough on EJ22 SOHC cam seal replacement (including the part where I remove the cam pulleys) I would appreciate it.
I have a 1997 Subaru Impreza OBS, (so I think it's probably a phase II interference engine).
<<M>> is offline   Reply With Quote
