Is your WRX bone-stock or was it modded by the previous owner?
Anyways, there are 2 very basic parts that are all you need to gain about 50hp. First is a downpipe. Second is engine management - a Cobb AccessPort for example. There are other EM systems but Cobb seems to be the most popular and n00b-friendly as well as very effective.
The downpipe can be had for between $200-800 depending on used/new and brand. The DP just needs to eliminate the cat directly after the turbo. With that done, you can flash a 'stage 2' map to your ECU from the AP. Bam = 50 horses, no CELs, better fuel economy, smoother power delivery. The AP should be about $650.
You don't need a BOV or an intake for WRXs. The stock BOV (actually BPV) and intake are superior the every aftermarket replacement until you get to a VERY high level of modification.
As well, if you're doing stage 2 (like most people will recommend) you should replace your uppipe with a cat-less one. You can gut the OEM cat, use an STi uppipe, or go aftermarket.
Once you go stage 2, you won't need a boost controller as your EM will control that.
Enjoy your car!
Here's a link to the best info threads on NASIOC. It might take a week, but read every topic, follow all the links, understand what's going on...You'll be waaaaay more informed when you're done! The answers to your next 10 questions are in here somewhere!
http://forums.nasioc.com/forums/showthread.php?t=533787
