Old 06-08-2018, 05:01 PM   #47
00_imprezaoutback
Member#: 452713
Originally Posted by grossgary View Post
98 Impreza EJ22 will bolt in and plug right into a 1998 Legacy GT EJ25. No wiring or ECU needed.
Use the 1998 single port exhaust manifold. The EJ25 is dual port exhaust. The manifolds easily interchange. Remove EJ25 manifold, bolt up EJ22 manifold.
Trans will bolt in just fine.
Front axles - use the 05 front axles and knock the tone ring off the outer joint? That works on 00-04 axles and will for 05's if they use the same hub-side set up.
I'm unsure of overall transmission length, multiple speed sensors, etc?
will a 00 legacy ej25 direct swap into a 00 impresa obs ej22???
00_imprezaoutback is offline   Reply With Quote
