Old 07-22-2019, 08:17 AM   #6
slow_impreza
Member#: 486479
Originally Posted by DrD View Post
How does the line from the master to slave look? there have been issues with that failing (leaking or collapsing) which will make it not bleed. have one person open the bleeder as or after you push it to the floor, then close it before you lift back up - it should come through eventually.
The line is in decent condition, when i put my finger over the hardline side and use my pump it sucks onto my finger. Sadly with my work hours in usualy awake opposite of possible help so i buy 1 person tools.
slow_impreza is offline   Reply With Quote
