Old 01-25-2005, 09:59 AM   #2
Member#: 3362
2001 I've wired a
Few cars in my day
You are best off getting another 2.2L engine and replacing what you already have in the car. You will not be gaining much performance for the amount of work that you'll have to put into doing the swap you are talking about doing and more than likely you'll also have to do some revisions to the wiring harness too. I'm not 100% sure on that though.
As far as the "Rally Edition" it sounds like this guy you are talking about put those on his car himself. It's quite easy to go to your local sign shop and get such decals cut.
If you are looking to Performance Rallies you are going to need a lot more than new engine in the car. You'll need a cage, seats, com gear, suspension, safety gear for yourself and codriver. You will also need to get a race license. The bottom line is you are going to be spending a ton of money to build a racecar when you are better off buying a car that has already been raced.
Zephyr is offline   Reply With Quote
