Thread: P0021 code??
Old 04-13-2017, 12:32 AM   #36
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
Default P0021 code??
Replaced cam gear, replaced OCV... hmmmmm... I'd bump oil pressure/ potential occlusion up higher in the list considering the new code and higher RPM AVCS movement.
Did you keep the old cam gear by chance?
Do you have a means of logging & sharing data yet?
What OCV did you replace it with? OEM? If so, why Subaru part number? any noticeable change in AVCS movement between old and new OCVs?
Subie_ is offline   Reply With Quote
