Old 03-16-2019, 07:12 PM   #57
Dash_Martino
Member#: 78728
04 STi
Nice weather means more garage time! Perrin subframe bushings installed:
Perrin Subframe Lockdown Bolts installed:
These definitely took a lot of turns with wrench before they went in all the way, but I can definitely see why they'll provide some rear end stability. Also used a tap cleaner before putting them in, bolt holes were rusty:
Also picked up an intercooler bolt stud kit so when I take the bypass valve off I won't drop the gasket as much.
Dash_Martino is offline   Reply With Quote
