Old 08-10-2019, 04:34 PM   #6
Blktrax
Member#: 220971
2002 WRX 224K Mi.
Originally Posted by lord_galathon View Post
I just wish I could get the keyfob/module sorted out. It works randomly, changed the battery in the keyfob but it still won't always work so I set it in "valet" mode just so that it doesn't set off the alarm each time I unlock the door with the key.
Check all the door switches, overtime the rubber covers wear thin or come off completely. Results in random door open signal. Second pull up the center console next to the parking brake; there may be an optional shock sensor for the alarm. Iíve been seeing this go bad after about 10years. Just unplug box , it will be labeled security sensor, and hopefully that takes care of it.
Blktrax is offline   Reply With Quote
