Old 08-17-2019, 10:05 PM   #356
BeepBoop
Member#: 496462
Originally Posted by n2oiroc View Post
magride fluid is abrasive, its inevitable that they will leak.
Sounds like more reason to go with good o'l fashioned stuff.
Cheaper? Check.
Easier to do maintenance? Check.
Less complicated? Check.
Less electronic garbo? Check.
More aftermarket options? Check.
Longer life? Check.
So you miss out on the ease of tuning your suspension at the twist of a knob (or in this case changing a setting via infotainment)? Big deal. Not worth the trade-off IMO.
For me to buy into something tech-wise, it has to be an across the board improvement. Not "Oh yeah, it's more expensive now... and it is also more expensive long-term!"
BeepBoop is offline   Reply With Quote
