Old 08-18-2019, 11:12 AM   #24
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Originally Posted by skier55 View Post
Should I just take it to a shop? They would probably extract it with an easy out and if that doesn't work pull the head (aka more or less a head gasket repair).
I don't know - I'd probably give extraction a try since I have the tools to do so. If it didn't go easily, I'd have it brought to a shop. If you do get it out, you need to inventory the bits you have and make sure you have the whole sparkplug - you do not want to find out you are missing a chunk of insulator the hard way! If the spark plug deformed/ovalized when it broke, it might not come out easily and could damage threads. On the plus side, it looks like the entire threaded section is there, and the deformed region would be at the top of the threads, so hopefully once it gets going it comes right out - if you lubricated the threads with some anti-seize before installation, there's an even better chance all will come out smoothly.
DrD is offline   Reply With Quote
