Originally Posted by BoxerLove
Noah,
So today I got it all wired to the ECU and did a test flash on my spare ECU. Here is the log.
Flash Development Toolkit and flash programming components
are provided without support
OS: Windows 10 (Windows 8) [Admin]
Disconnecting
Disconnected
Clock Frequency (External) = 10.0000MHz, Clock Mode = 0, CKM = 4, and CKP = 2
Connecting to device 'SH/7058F' on 'COM4'
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'COM4' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Attempting 9600
Received immediate response from device: 0xE6
Detected generic boot device
Sending inquiry for getting line size
Buffer size has been set to default (128 bytes)
Sending selection of device command
Selection of Device - Device selected, code 0601
Sending selection of clock mode
Selection of Clock Mode - Clock selected, code 0
Changing baud rate to 57600 bps
Set baud rate value = 57600
Determining block usage
Connection complete
Processing file :"C:\Users\Anon\Desktop\A2ZJB10J.bin"
Loading image file : 'C:\Users\Anon\Desktop\A2ZJB10J.bin'
Operation on User Flash
Loaded the Write operation module
Writing image to device... [0x00000000 - 0x00000E7F]
Writing image to device... [0x00000F80 - 0x00001F7F]
Writing image to device... [0x00001F80 - 0x0007B07F]
Writing image to device... [0x000C0000 - 0x000CADFF]
Writing image to device... [0x000CAE00 - 0x000CD6FF]
Writing image to device... [0x000FFA80 - 0x000FFAFF]
Writing image to device... [0x000FFB80 - 0x000FFFFF]
Data programmed at the following positions:
0x00000000 - 0x00000E7F Length : 0x00000E80
0x00000F80 - 0x00001F7F Length : 0x00001000
0x00001F80 - 0x0007B07F Length : 0x00079100
0x000C0000 - 0x000CADFF Length : 0x0000AE00
0x000CAE00 - 0x000CD6FF Length : 0x00002900
0x000FFA80 - 0x000FFAFF Length : 0x00000080
0x000FFB80 - 0x000FFFFF Length : 0x00000480
546.88 K programmed in 106 seconds
Image written to device
Disconnecting
Disconnected
Does everything look ok here? Seemed quick compared to the OP's post. I noticed some differences in his vs my log. Wondering if thats because my ECU had the 7058 chip?
Just wanted to be sure of myself and my setup before attempting the ECU I believe is locked in my car now.
I was using a purchased Adjustable NE555 device that I set to 125-150 HZ and checked with my Fluke 77 IV multimeter on AC HZ mode, And my USB UART
If you've made it to the highlighted section, you're good to go. The 2004 STI uses the SH 7055 chip, all revisions after 2004 used the 7058 chip so no worries. It looks like you flashed a 2005 STI ROM on to your ECU. If that's correct and it matches your car, plug it in and make sure your car starts.
