Old 08-24-2005, 08:49 AM   #17
jays05
Member#: 78165
05 STI 35r + e85
As mentioned above, pumping the gas (and not just holding a certain rpm at the line) will spool the turbo nicely. I've been playing around on an open downpipe the past couple days, and when revving the engine in the 5000-5500rpm area you can hear that the turbo is already spinning pretty fast. There are a lot of different ways that people launch, I prefer to slip the clutch initially, then once the car is moving I drop the clutch to transfer all the weight to the back. I've cut 60' times as low as 1.66 so I guess this works. DCCD open and all the way to the back is the fastest, but as others have mentioned it is pretty abusive on your rear axles.
jays05 is offline   Reply With Quote
