Old 07-16-2020, 12:45 PM   #2
joebush44
Member#: 163483
1998 07 swapped RSTi
Diamond Black Pearl
Pull up to slide the spring out. Careful because it will snap shut and could pinch your finger!
Next, on the side of the case remove this bolt, spring and ball (top center of picture, partially backed out)
With that removed, these will both pop out together
You should be left with a view similar to this
Remove all of the torx (size 40) bolts holding the oil pump block plate onto the housing. (Note: this transmission is out of a late '07 STi so it no longer has the trans oil pump. This section will be slightly different for 04-06 STi transmissions. Please refer to the FSM for any missing steps here)
Pump block plate removed
cont...
joebush44 is offline   Reply With Quote
