Old 07-18-2019, 08:30 PM   #2
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Hopefully you have the clutch switch hooked up at the pedal and on the trans end. The crappy thing is you never know what condition the ignition/immobilzer parts inside the vehicle are, unless you actually saw it running just before they removed the bad engine.
Does the immobilizer light on the dash flash? Some vehicles have to have the ecu programmed separately from the keyless, which is how I believe yours should work. The key can be programmed to the keyless module, even if the immobilizer setup isn't programmed to the engine ecu. I'm unsure whether or not that subaru will preven the starter from turning over if the immobilizer isn't programmed though.
