Old 09-11-2008, 10:57 PM   #58
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
So after getting my car corner balanced a couple months ago and realizing it weighs close to 3300 lbs, I knew some weight reduction was in order. The car is still a street car so obviously I'm a bit limited in what I'm willing to do, but that might change before next season
For now, I'm just going through the car when I have spare time and removing things I don't need or use. This past week I removed all of the stock seatbelts, the latch system, and the windshield washer tank. Since I don't use the i/c sprayer, I connected that hose to spray the windshield. I haven't weighed everything but I'd say I removed at least 30 lbs. total. I also moved the catch can over to where the washer bottle was to clean up the engine bay a bit.
In addition, I have melted through the rubber hose that goes from my BCS to the wastegate 2 or 3 times now. I got fed up with it and decided to replace it with a braided stainless line. I also began gathering the parts to replace my AVCS line with braided stainless. Here are some pics:
Lots of seatbelt stuff:
Updated engine bay:
Catch can closeup with the bracket I threw together:
Line going from BCS to wastegate. It's a short rubber hose going to the BCS, which is connected to the SS line going to the wastegate:
Still looking for more ways to reduce weight, I'll eventually go all out and remove the a/c, sound deadening, etc. but for now it's just little stuff.
boost junkie is offline   Reply With Quote
