Old 01-21-2021, 08:24 AM   #29
Dwbarrett7
Member#: 421948
2017 WRX STI
WR Blue Pearl
Default I need a solution too
So, within the past 6 months I have gone through 3 front o2 sensors on my 2017 STI. I have been replacing them with the factory OEM Denso 02 sensors from my local Subaru dealer. Easy fix but this is getting kinda expensive and shouldn’t be happening. As they start to go I notice them becoming sluggish as I’m monitoring AFR with a wideband 02 sensor that’s located in my rear 02 bung. I am tuned for this and have a Visconti wideband logging cable. As they become very sluggish the car during cold starts will dump so much fuel in it hiccups and can’t ignite all the fuel which triggers a CEL for random cylinder misfire. Eventually it heats up and gets better but not perfect. The car has roughly 18k miles on the new build and it started this behavior around 12,000 miles in. Currently right now I have been running 93 octane since the last o2 sensor install to test if it was the E85 that was causing it and well here we are. I have got under the car and looked for exhaust leaks and it appears there are none. For an exhaust I am running a killer b ELH, Grimmspeed EWG Uppipe, Grimmspeed catted DP, and a Invidia q300 catback. The car is tuned for a target AFR of 13.5 AFR at idle which I know is kinda rich but the car is happiest here according to my tuner. It’s got fully built heads so I’m assuming the engine just flows really well. One other thought of mine was condensation was killing the sensors prematurely as I notice a lot of steam out the exhaust during cold starts but once again I went 12k previously without any problems. Any thoughts on what could be killing these 02 sensors so quickly?
Dwbarrett7 is offline   Reply With Quote
