Old 07-21-2010, 03:39 PM   #2
girodisc
Member#: 177674
You going to just do the motor swap or you buying a wreaked STi so you get everything. If you going for a whole Sti get a 08-09. It will cost more but then you can use all the suspension goodies because they share the same setup.
There shouldn't be an issue with an outback over any other legacy model. If you are doing the tranny swap find a car that's a manual too unless you are swapping the harnesses as well. Converting a Automatic Harness to work correctly with a manual is a PITA.
Buy one with an h6 in it and all buy your motor and crap haha.
Johann @ Girodisc
girodisc is offline   Reply With Quote
