Old 10-03-2012, 04:40 PM   #12
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
You will need to spend a nice amount on equipment, spent over 650 on mics and gauges and stuff, still need a ring rile, piston ring compressor, torque plates (some day)
so thats like a thou, + paying someone for machine work on honing and valve job. but you will understand it, be able to do other and possibly make that money back, peace of mind is the biggest thing, if you can understand it all, there are plenty of building video's out there, whether its a subie motor or not, look at the high quality builds to understand what it takes for perfect, even if you cant do all that
as for the oil pump, isnt sticking with the stock 04-07 sti size pump of 10mm good enough for a daily driver, with no more then 500whp (04 sti)?
does this have to do with single avcs 10mm, dual avcs has 11mm?
Irv Weissmanhowerton is offline   Reply With Quote
