Old 01-20-2009, 03:52 PM   #14
Member#: 38829
Not your usual 1997
Legacy GT
Originally Posted by GrimmSpeed View Post
Sounds very similar to our NA RS build! the only problem we really ran into was adjusting the valve lash.. maybe check that out?
Thanks for the reply. I just had a valve job done (valve seat grind, new stem seals, new retainers) and they adjusted the valve lash to factory spec. which is what John at Delta recommended. I was told by one member here to open them up a little bit, but I'm a little leery to do so since it's such a pain to adjust them all... especially since I've already got the motor installed!
What did you adust the lash to on your RS setup?
fastenova is offline   Reply With Quote
