Originally Posted by asaturn
you should insert a relay in place of the factory light, then wire the relay and a positive feed from the battery as well as a frame (ground) to the 500s... they pull more power than the factory lighting.
technically it will "work" with just plug and play, but you'll get more light from the above method.
I thought they both used the same H3 55w bulbs
