Old 11-03-2012, 11:03 PM   #4
Member#: 256615
I would not use the factory header as those are a pain in the ass to install on a motor which means that if you use those as a reference your header will fit the same way. Measure from the studs on the heads and transfer those over to whichever material you choose to make a fixture out of. the part you are trying to make will only be as good as the fixture you build them in.
TIGWERKS is offline   Reply With Quote
