Old 10-11-2012, 03:11 AM   #14310
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by Blackmamba24kb View Post
so tucking the strip underneath those tabs do work, it helps a lot, there are some parts that arent under the tabs that want to detach from the headliner but for the most part its the solution!
thanks again kenny for the suggestion. i just unclipped the clips a tab to get part of the strip under it and presto.
ans2k: i think the brightness of the 12 smd led panel will provide sufficient light for the side cargo net area. again it all depends if there are obstructions to the area of light. but it works for the most part (definitely way better than the stock bulb) if you dont want to do the strip. just ordered another strip in case this strip goes bad for the future. so far so good.
I swapped out the stock bulb for a T10 42 SMD LED and illuminates the hatch really good. I may choose to go the LED strip down the road, how much did it cost?
