Old 10-08-2008, 09:15 PM   #19
greenemac2003
Member#: 38813
1999 RS ej20/stg2 AP
silverthorn
Originally Posted by kheff46 View Post
i did a V4 Sti swap GC-GC and used entire JDM STi wiring harness. it was much faster and simpler this way. but GD to GC iirc under dash plugs are different. a WRX ECU would be easy to use if you went full GD wiring though.
i would use OEM everything to start with because 1) it's legos and it'll all fit, and it gives a good baseline/reference point for tuning, mods, etc.
--keith
and im jealous of the $1700 shell as well
Na man, I leave the RS harness in place, cut the WRX ecu connectors, splice them into the RS harness and plug the WRX ecu in. Of course it's a little more complicated than that, but that's what I do...
greenemac2003 is offline   Reply With Quote
