Old 07-23-2014, 07:31 AM   #25
DDS4
Member#: 391676
2018 Tesla Model 3
2012 Infiniti G37x
http://legacygt.com/forums/showpost....55&postcount=1 The 10 pin connector listed here has the same pin-out numbers as the side mirror connector. Pin 5 is the black ground wire and pin 1 is the left or right signal.
If you are looking at the service manual it is under the "Turn Signal Light and Hazard Light System" "Wiring Diagram".
I started researching this a month ago because I want to make the same change. I ordered my car in May and will not receive it until August.
DDS4 is offline   Reply With Quote
