Old 06-19-2016, 03:03 PM   #5
waltersh
Member#: 447706
2017 WRX Base
CWP
Originally Posted by obiling View Post
That's absurd, are those just cheapo plugs or what? When I changed my plugs, all 4 came out real easy. I can't imagine if one snapped or if the thread came off, how does that even happen...talk about a headache.
If I were in your shoes I would bring it to a shop and admit defeat. It's unfortunate that what seemed like a simply task turned out to be the opposite but the last thing you want to do is make it worse.
If you really can't tow it to a shop and you want to do it yourself, there are plenty of videos on YouTube that feature people in the same situation as you. Do a little research and maybe one will work.
Good luck !
They're NGK Laser Iridiums (~$14/plug) so they are some of the nicest consumer plugs available. They were almost definitely over-torqued.
OP, it's possible the head can be saved, but unless you're very confident in broken stud removal, then I would suggest taking it to a shop as well.
Good luck!
waltersh is offline   Reply With Quote
