Old 03-24-2018, 08:17 PM   #1314
SlickWRX
Member#: 17312
2015 WRX STI Limited
Dark Grey Metallic
So in the interest of following up on the passenger door sounds with the HK premium system on the 2015 STI, I ordered the part that is supposed to correspond to the premium sound.
PAD - SUBARU (61208VA010) - Premium Sound (https://www.subarugenuineparts.com/o...pad-61208va010)
PAD - SUBARU (61208FJ000) - Without Premium Sound
I removed (61208FJ000) which one YouTuber (
) said *should* fix the issue. If anything it made it worse. I will try out the newly ordered part by itself. If that does not fix it I will go completely overboard on padding and isolating things in the door. BTW, I asked SOA about this and they gave me a really **** answer and told me to go to a local dealer. The same local dealer who didn't presumably install the correct parts in the first place.
BTW that part is $17 and change, so whatever. If it works then great. If not oh well, it's not a lot of money.
Edit: Part came in. Not sure how I got it mixed up but its for the left side, not the right, which is what I would have wanted. The part is exactly the same though. Oh well.
SlickWRX is offline   Reply With Quote
