Old 12-30-2012, 09:29 PM   #5
02SilvaWagon
Member#: 33933
2011 WRX Limited
Can we get a little more background info? Has the car ever been running correctly with both the alarm and standalone ECU in the car? Which was put in first? When did the issue start happening?
Did you install the alarm yourself? What alarm related wires did you connect at the ECU? Tach is common there, but there could also be connections for the Neutral Sensing Wire and maybe others.
02SilvaWagon is offline   Reply With Quote
