Old 09-25-2002, 01:46 AM   #6
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
Since it removes the long term fuel trim and allows the ECU to learn faster, it only enrichens if you need it. It also advances timing. The powerchip is similar and improves power approx 4hp across the board on the dyno... I expect this would do the same as proECM and the Manufacturer claims max 12 ftlb gain and about 4hp from the dyno plots I have seen previously.
ImprezaRS dot com is offline   Reply With Quote
