Have I posted a statement with any similarity at some point in the past? Even had I failed to recall the iteration, it surely would not have been to the extent to be called a chant. If I offend you or your sensibilities tell me, if my information is inaccurate, skewed, flat out wrong, tell me, if you don't agree or I am unclear tell me. I have no issue being confronted, even when/if I am shamed by my decrepit knowledge ( not uncomone ). However, I have no idea what the intent of your post is; are you asking what I meant or just being mean? Maybe it was the poor choice of words on my part, will it help to know I am not talking about function inlining?
CPU......LINE.....SENSOR
[__]-----------------<>
OBDII
CPU......In-LINE.....SENSOR
[__]--------^--------<>
OBDII
Assuming you are defeating the ECU, any signal read from the OBDII interface is going to be a reflection of the adjusted signal the ECU received. This has even been an issue when dealing with excessive noise effecting sensor input signals and translating to inacurate/incorect logging.
SLR-
