Old 09-11-2019, 03:33 AM   #31
subaru_gc8
Member#: 29292
2004 WRX wagon
Originally Posted by cashrolling View Post
I was looking into that same turbo. What's ur numbers like with it? I wouldn't mind an earlier spool as long as the power doesn't drop off at higher RPM...
im tuned to 22 psi and 380 is what I have, it doesnt fall, on the top end, but the way it was explained to me is, if your turbo falls off you need a bigger hotside, basically it chokes the turbine housing so you need a bigger ar, but you suffer a little on the other end. mine seems to spool around 3700ish and goes all the way to 8000 but I do have a 2.1 so yeah might spool a little faster than a 2.0 not really sure. but really what i wanted was a fat power band and Im pretty happy with it. I mean its not the fastest but I can beat mustang and camaros all day long
