hey all, i have done all the typical misfire checks. I've done the following:
Clean Maf sensor
New spark plugs (gapped at 0.028)
Inspected all coil packs (did swap 2 to 1, but since no stored CEL i have no idea what cylinder is misfiring)
Completed a compression test this morning
Cylinder 1: 122
Cylinder 2: 124
Cylinder 3: 124
Cylinder 4: 120
Replaced in-tank fuel filter and fuel pump sock as well.
Did a datalog (included below) and only see roughness counts on cylinder 3. Swapped coilpack with cylinder 1 with no change***8230; I was thinking possibly injectors but looking at the datalog i'm assuming it's not that.
Only modification change in the last 6 months is a new clutch and lightweight flywheel. Car was tuned with the factory clutch kit and flywheel, so i'm unsure if that would contribute like it used to for the ej20's.
Any help would be appreciated, thanks in advance.
PS Data log was cut short due to having a dinosaur V2 and sometimes it stops datalogging mid-way.
Datalog:
https://docs.google.com/spreadsheets...it?usp=sharing
modlist:
vf48
13 sti tmic
walbro 255
invidia catless downpipe
spt intake
grimmspeed ebcs
protuned back in 2014 by Sean at Church in LA
