so since i am seeing good power to the starter, and the solenoid receives power when trying to crank, can i assume the starter is trash? i have checked all the grounds i can find, i jumped the upper clutch switch and i am receiving power to the solenoid so im certain that the bypass is proper, and i assume that the ignition switch is fine since i am measuring power at the solenoid when trying to crank.
