Originally Posted by subaru_gc8
the 207 rods are the same as the 257, so not real weak but they arent h beams or i beams. you know even though you have a the engine you have, it is still a stock engine and it is a 2.0l and a 35r is a pretty sizable turbo. To me that it sounds about right as far as a 35r on a 2.0l. what ar turbine housing are you using? I ahve a 2.1 with V9 heads and with my gtx3067 I spool at 3700ish with a tial ,82 but i have power all the way to 8000 too. so yeah, I mean any way you look at it, its a 2.0 not a 2.5 or a 3.0 v6.
I do have a question, what gas are you using?
I was looking into that same turbo. What's ur numbers like with it? I wouldn't mind an earlier spool as long as the power doesn't drop off at higher RPM...
