Old 03-23-2010, 06:02 PM   #13
PrecisionCustom
Member#: 207830
2002 Precision Built
Pulse was designed strictly for penetration (thin material) and AC welding. It has nothing to do with puddle control. The angle of your torch, gas psi, size of cup, size of tungsten, high frequency start, and height of torch from work piece control puddle variance. But to be honest (Kenny AKA gmrsti) any noob can lay a bead like that in a grove where 2 metal thickness meet. Looks good, im not hating but the welding talk is just fun. 180pps you might as well just weld that mother in standard. gas to 25psi, 3/32 Thoriated Tungsten, sharp to a point with vertical grinding and 1/8 from collet body. your set to make a freaking rainbow. Your welds are almost hot enough that its burning the nickel content out of the stainless.
PrecisionCustom is offline   Reply With Quote
