Old 12-05-2019, 07:48 PM   #2
NighthawkSTI
Member#: 495630
2500 ish' is a normal high idle warm up RPM....my outback does that...if your dropping it into reverse at that RPM before letting it warm up and idle speed settle down then its normal for the gear transition to feel more aggressive. Let it warm up for a few minutes and idle should start to come down, or blip the throttle before going into gear to drop the idle down faster.
NighthawkSTI is offline   Reply With Quote
