Old 09-06-2006, 02:52 PM   #8
Member#: 70296
04 WRX
rally blue
Originally Posted by SparkysJDMSpeedWagon View Post
Nicely done! A VF30 should make almost exactly the same power as a VF34, since they're both the same design. The only difference between them is that the VF34 is ball-bearing, so the spool is faster, but the power is the same.
Thanks, I'll add the change
Originally Posted by peterex View Post
Nice chart. What gear was used to obtain those spool times? Makes a big difference.
To be honest I'm not sure what gear all those were done in. I just looked through a ton of threads to get those numbers, some people noted it, but most didn't.
I'll try to go through them again, and see what I can pick up.
WoohooRX is offline   Reply With Quote
