Old 03-04-2014, 11:35 AM   #21
Razgeiz
Member#: 358782
2013 STi
Originally Posted by TyranosaurusWRX View Post
Just an update.... replaced the oil pick up (yes, with the Killer B ;]), pulled and cleaned out the oil cooler just in case, replaced filter and oil. I'm only getting about 5-10psi more out of it. I'm thinking that's more the 15w-40 rotella than anything. Maybe it's in the build but I'm not seeing where. I fount my notes regarding the ACL main bearing clearances and they were all right around .0015 via plastigauge....So not sure what else to look for but the search goes on.
Sad face for the plastigauge your clearances are probably off from what that sheet says.
Razgeiz is offline   Reply With Quote
