I thought you could remove the brake boost limitation in the ECU but I could be wrong. Your tuner said they can't remove the limit?
but yeah if you can't brake boost you are pretty limited to rpm because what else is there right
There is rolling anti-lag! Like brake boosting, only its easier and you don't need both feet
The jump off the line it gives you with the makeshift launch is insane.
