Welcome to the North American Subaru Impreza Owners Club Saturday January 20, 2018
Old 02-22-2012, 07:55 PM   #1
02rallywagon
Member#: 286849
Default overheating issue!
heres the breakdown i have an 02 wrx wagon with 94k miles
i did waterpump t stat timing belt 6k ago
driving home from work one day i noticed the temp rising, after that it will rise once car is warmed up and temp can only be brought down by reving engine past 3k rpm anything under that and temp rises, my coolant level stays about the same, if anything it rises
so far i did a compression test on the coolant system- it passed
i also did the chemical test to test for exhaust gases- passed
i also have poor heat barely gets warm
it sounds like head gaskets but it passed the tests, ive tried a new tstat for giggle but no luck, any chance it could still be head gaskets
02rallywagon is offline   Reply With Quote
Old 02-22-2012, 07:59 PM   #2
Rally Monkey
Member#: 36310
03 WRX Sedan
Air in the coolant? Did you try burping it again?
Rally Monkey is offline   Reply With Quote
Old 02-22-2012, 09:02 PM   #3
WagonMafia23
Member#: 273900
02 wrx
SRP
Yes try burping it open radiator cap and squeeze on the radiator hoses and see if bubbles come from the cap
WagonMafia23 is offline   Reply With Quote
Old 02-23-2012, 01:30 PM   #4
02rallywagon
Member#: 286849
I've tried that a couple times and got no bubbles
Old 02-23-2012, 02:15 PM   #5
hardball75006
Member#: 214319
2009 Legacy 2.5 NA
Diamond Grey Metallic
A blocked or partially blocked heater core?
hardball75006 is offline   Reply With Quote
Old 02-25-2012, 10:15 AM   #6
REDrexsti
Member#: 283553
2004 wrx
jbp
Its a pretty good bet that there is air in the system. Sometimes it helps if you try burping the system with the front of the car jacked up. There is a tool you can get that works very well, I've seen it refered to as an air purge tool. I use one and they work well.
REDrexsti is offline   Reply With Quote
Old 02-25-2012, 01:19 PM   #7
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Just verifying, are you looking at your coolant level in your filler tank or your overflow?
Is your overflow filling up alot after driving? If so, try a new radiator cap since you already did the chem test.
Thermostat / overheating issues Sort of odd issue psychoskip Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-15-2009 09:18 PM
2002 wrx overheating issue rotaman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-19-2006 07:09 PM
'97 2.5 GT with overheating issues StarryNights Legacy Forum 10 04-01-2006 10:07 PM
Overheating issue... MekoNY Legacy Forum 5 10-04-2004 01:46 PM
overheating issue jr34596 Legacy Forum 8 08-19-2002 03:19 AM
