Welcome to the North American Subaru Impreza Owners Club Saturday April 29, 2017
Old 09-12-2003, 03:47 PM   #1
Tomnel
Member#: 12625
MY02 WRX Impreza
Default OEM Filter always leaks
I'm on my 9th change and wondering, do any of your oil filters leak after a few days?
Every oil change I get some oil down the side of the filter and I hand tighten it, put oil around the ring etc.
I used aftermarket purolator a few times and those would spray oil on the bottom of my engine so now I am back to OEM but it still leaks a little.
Tomnel is offline   Reply With Quote
Old 09-12-2003, 04:02 PM   #2
Karl
Member#: 13110
Have you wiped down the surface where the filter contacts the oil cooler?
Karl is offline   Reply With Quote
Old 09-12-2003, 04:17 PM   #3
orndog
Member#: 34670
2016 slowmobile
Have you checked the stud that the filter spins onto? My guess is with the above (dirty mounting plate).
Also, how tight are you making it? Too tight will give you leaks too.
orndog is offline   Reply With Quote
Old 09-12-2003, 06:27 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I bet its not the oil filter leaking. It could be the cam seal dripping down into the timing belt cover which sprays back against the filter in the wind!
ciper is offline   Reply With Quote
Old 09-13-2003, 04:07 AM   #5
Tomnel
Member#: 12625
MY02 WRX Impreza
Yep.
Check it for what exactly? It seems fine.
Cam seal? is this something I need to get checked?
Thanks guys.
Old 09-13-2003, 05:21 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
You need to have a mechanic look at it. Either there is a flaw in the threading that the filter is screwed onto, or there is a flaw in the flat plate that the filter's rubber gasket presses against, or there is a flaw in some part of the engine very nearby that area that is leaking oil *onto* the filter (not *from* the filter).
Life would be very bad if the something that's wrong suddenly gave way and dumped your oil out of the engine, so get it checked out soon.
armand1 is offline   Reply With Quote
Old 09-14-2003, 04:01 PM   #7
Frawl
Member#: 19201
2008 Legacy Wagon
I had this happen with an entire six pack of OEM filters. I have an Impreza and a Legacy - happened on both. Thought the gasket was failing, or something was wrong with the seating surface. After the 4th one I got fed-up and tried a Napa Gold filter on one the Legacy and the problem went away. I'm now running an Amsoil filter on the other and the problem is gone on that one too.
A couple of months ago a mechanic told me that Subaru (at least in western Canada) had recalled a batch of filters. I asked a dealership and they just spaced - no surprise for a dealership I suppose. Anyway, I'm having no problem with the aftermarket filters I'm now using. Still have two new OEM filters that won't even work as doorstops because they're not heavy enough...
Jeff
Frawl is offline   Reply With Quote
Old 09-14-2003, 11:19 PM   #8
Yungimoto
Member#: 14940
It seems odd that you'd have the problem every time. I could see getting a defective filter once, but 9 times? Something else has to be wrong.
Good luck!
Yungimoto is offline   Reply With Quote
DIY coolant overflow tank? The OEM sprung a leak. BigRed06 Service & Maintenance 12 12-18-2009 11:56 AM
2k2 ts, new filter=exhaust leak type sound? danfranklin6 Normally Aspirated Powertrain 4 10-02-2008 10:32 PM
FS:OEM Airbox w/ K&N Filter+NEW OEM filter obsti2 Engine/Power/Exhaust 21 09-15-2008 11:01 AM
No matter what I do oil filter still leaks Porkchop-WRX Service & Maintenance 18 05-07-2003 04:23 PM
filtration specs of oem filters gravel Service & Maintenance 1 06-27-2002 05:16 PM
