Welcome to the North American Subaru Impreza Owners Club Tuesday May 23, 2017
Old 11-29-2003, 06:00 PM   #1
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
Default VF36 + 17.5psi + Turbo XS = 12.058 @ 115.27!!
+ a few other things (all of which I have listed before)
No change from my previous runs in terms of set-up... same boost, same turbo... a couple gallons of c16 and a good launch!
60- 1.761
330- 5.007
1/8- 7.746
mph- 90.84
1000- 10.093
1/4- 12.058
mph- 115.27
My best sixty foot for the day was 1.743 and my best trap was 115.48, so I am leaving oooh such a little-bit left on the table.
I sooo wanted a 11.999!!! Oh well... close enough for now.
def
dug-e-fresh is offline   Reply With Quote
Old 11-29-2003, 06:11 PM   #2
Spooled
Member#: 14958
1991 318is
Awesome run. Sounds like things are working out for you.
Spooled is offline   Reply With Quote
Old 11-29-2003, 06:26 PM   #3
nmyeti
Member#: 4980
Nice Job!
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 11-29-2003, 07:41 PM   #4
mikaust
Member#: 7468
2008 Outback Limited
serious times Doug !!! We got two more Saturdays to race. With some new tires you should be able to hook up even better !! I have enough c-16 for next week. gud on ya!!
mikaust is offline   Reply With Quote
Old 11-29-2003, 07:59 PM   #5
cronic
Member#: 9749
Hey man awesome times.. I cant believe you are doing those times on basically a stock JDM motor.. What kind of Hp did you pick up after the tune? Also are you using only utec or ecutek flashed JDM ecu and utec?
Dave-
cronic is offline   Reply With Quote
Old 11-29-2003, 08:17 PM   #6
Protoz
Member#: 13612
2002 Black WRX
11.813 @ 123.14
Congrats on the amazing time!!
I know you will get an 11 sec pass out before this track season is over!
Let me know when you and Micheal go to the track next... maybe I will finally get my 12 sec pass
Protoz is offline   Reply With Quote
Old 11-29-2003, 10:45 PM   #7
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Why don't you up the boost a little? I am sure that turbo could still be efficient at 20 or 21psi. Or are you out of injectors?
mr2guru is offline   Reply With Quote
Old 11-29-2003, 11:15 PM   #8
AjIsDope
Member#: 32660
^^^What he said. Nice run!
AjIsDope is offline   Reply With Quote
Old 11-30-2003, 01:02 AM   #9
wrxpyro
Member#: 39547
2003 EVO
20 psi is a bit much for that turbo I think its not that big but damn doug your the man I have been thinking of going the same path as you as with the motor but your making my decision easier and easier with these damn times of yours
wrxpyro is offline   Reply With Quote
Old 11-30-2003, 01:36 AM   #10
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
not that big? his speeds suggest ~370whp That is more than any PE1820 I have seen on a light race gas mix.
Old 11-30-2003, 03:21 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
damn dood, that car just keeps getting meaner....glad to see the setup is working out for you, when does that twin scroll spool up??
HndaTch627 is offline   Reply With Quote
Old 11-30-2003, 05:24 AM   #12
mlambert
Member#: 13831
I think Doug is one of the reasons people are hyped on twinscroll setups. I cant believe an IHI is pushing a wrx to 115mph on a low boost street tune. Simply amazing.
Id love to see what a PE1825 would do.
mlambert is offline   Reply With Quote
Old 11-30-2003, 09:07 AM   #13
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
VF 36 is holding up very well.
awesome times man.
stickman is offline   Reply With Quote
Old 11-30-2003, 09:26 AM   #14
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Keep up the good work man!
-bd
Butt Dyno is offline   Reply With Quote
Old 11-30-2003, 09:29 AM   #15
wrxpyro
Member#: 39547
2003 EVO
not that big?
yup not that big even doug will tell you the turbo is small so just imagine what he could do with a bigger turbo like a 18G or even a FPgreen. and the hp numbers are correct 370ish but for the exact Doug or Nathan would have to let you know. Also doug is not a small guy (not saying your fat doug) but if he was like the size ofa midget he could probally hit 11s
Old 11-30-2003, 10:37 AM   #16
mikaust
Member#: 7468
Doug I'm glad you finally took my launching advise The c-16 is the shat !! forget cam-2
Old 11-30-2003, 03:23 PM   #17
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
sweet run man.
Damn those elusive 11's!!!
I ran a best of [email protected]..
SOOOO godamn close!!!
Ahwellz... it happens.
That still kicks ass either way you look at it.
~v6
V6TurboTA is offline   Reply With Quote
Old 11-30-2003, 03:50 PM   #18
AjIsDope
Member#: 32660
Do you have any links where I could read more about these twinscrolls? I'm not too familiar with them. Thanks.
Old 11-30-2003, 04:37 PM   #19
Hassassin
Member#: 16771
12.9 @ 102MPH
1.784 - Stock Turbo
damn doug!!! good work!!
now its time for 11s
Hassassin is offline   Reply With Quote
Old 11-30-2003, 06:44 PM   #20
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
That is fast! Your sti frankenstien motor is kicking some ass
PaulRex is offline   Reply With Quote
Old 11-30-2003, 07:01 PM   #21
j-speedracer
Member#: 48897
02 WRX
you doing this on stock tranny?
j-speedracer is offline   Reply With Quote
Old 11-30-2003, 07:04 PM   #22
nmyeti
Member#: 4980
Doug made like 330whp or so on our dyno.
Clearly there is some HP from the FMIC that doesn't show up when the car is on the dyno.
The twin scroll setup won't push anymore boost at high RPMs it's actually a pretty small compressor wheel, but with the VE benefits of the twin scroll exhaust housing, the motor is making very good use of it.
Doug is a pretty good driver and is making good use of the HP available to him. Great job!
-Nathan
www.turboxs.com
Old 11-30-2003, 07:08 PM   #23
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Good job DEF!
Need4Boost is offline   Reply With Quote
Old 11-30-2003, 08:47 PM   #24
motorcitywrx
Member#: 22952
2014 STi Hatch
Awesome times. Maybe this is telling us our usdm stg 4 cars could really benefit from better heads and cams! Or maybe its just the tune and gas. -Wayne
motorcitywrx is offline   Reply With Quote
Old 11-30-2003, 09:00 PM   #25
mlambert
Member#: 13831
or maybe its a combo of awesome heads, cams, twinscroll, alittle c16 and an awesome driver
