Welcome to the North American Subaru Impreza Owners Club Wednesday May 18, 2022
Old 09-20-2005, 05:17 PM   #1
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Default Zzyzx Motorsports 2.5 RS breaks 300 NA HP
Here's the official Press Release. The dyno graph is posted here on the website.
FOR IMMEDIATE RELEASE
September 20, 2005
Zzyzx Motorsports Impreza 2.5 RS breaks 300 NA horsepower
TechWorks Engineering (Calgary, Alberta, Canada), Dieman Motorsports (Lees Summit, MO) and Zzyzx Motorsports (Overland Park, KS) conspired to build the most powerful normally aspirated Subaru 2.5L Flat-4 in North America. At more than 300 CHP, the output shatters any previously documented efforts to date.
Utilizing an MD Mustang IMP dynomometer, the engine output hit 235 WHP at 6450 RPM and 209 WTQ at 4600 RPM. "We typically see 233 WHP for a WRX STi, which is rated at 300 CHP, comments Jake Diehl, owner of Dieman Motorsports. "This engine puts down roughly 185 WTQ at 2000 RPM and carries a nearly flat torque curve up to 4600 RPM where it makes 209 WTQ, then tapers off to roughly 185 WTQ at 6500 RPM. Though the peak of 209 WTQ is at 4600 RPM, peak numbers don't readily describe the output of this engine. There is more power under the curve than any stock STi can wish for. Based on the average WRX STi, WRX and 2.5 RS data for our dyno, we're looking at peak outputs of roughly 302 CHP, and 276 CTQ."
The longblock was built entirely by TechWorks Engineering. "The recipe for the engine is less exotic than most would guess.", comments Tom Penner, owner of TechWorks Engineering. This engine uses our off the shelf 11.2:1 CR forged pistons, Stage II SOHC Street cams and headwork to maximize both velocity and flow. We consider this a Stage III engine build as it requires high-octane gas and stand-alone engine management, but simply lowering the compression ratio would still yield impressive output in a more streetable configuration." The TWE headers are a race-only 4-2-1 design, with large primaries. "The design of the headers was twofold: to provide power up top, and to lower dynamic compression in the lower RPMs to avoid torque spikes and detonation.", comments Tom. The trough in the torque curve from roughly 3000 to 4500 RPM is a direct result of the header design.
"I knew we needed to find a different intake manifold as the pre-2005 designs clearly are not meant to make power up top; this is a well documented.", comments Steve Sulatycki, owner of Zzyzx Motorsports. "Looking over the options, it appeared the 2005+ 2.5 RS intake manifold design was clearly superior and I decided to mate a high-flow 65mm throttle body to the '05 intake manifold. I had no idea what kind of numbers we'd be making."
"Once the car made it's first 220+ horsepower pull with very little timing and 11.5:1 AFRs we knew we had a strong motor on our hands. I proceeded to level out the AFRs to a very conservative 12:6:1 AFR and we started making pulls in the 230+ WHP range.", comments Jake. "As this engine was built and is being used for road racing, we stayed with a conservative tune for longevity. This is no dyno queen, and these numbers are real-world, not one-offs."
"The engine makes power everywhere", comments Steve. "This kind of power is useable on the street, at an autocross or road racing. It's perhaps the most versatile power delivery you can ask for and the flat torque curve results in a very predictable and controllable chassis when you have the car at it's limits."
The dyno graph is available at the Zzyzx Motorsports website.
Contact Info:
Tom Penner
403-288-8568
http://www.techworkseng.com
Jake Diehl
Dieman Motorsports
816-347-1950
http://www.diemanmotorsports.com
Steve Sulatycki
Zzyzx Motorsports
913-706-5496
http://zzyzxmotorsports.com
zzyzx is offline   Reply With Quote
Old 09-20-2005, 05:22 PM   #2
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
I like that type of power, but what is the approximate cost to turn a stock RS or i into this type of performer? Did they keep the stock clutch and trans?
SilverSurfer04STi is offline   Reply With Quote
Old 09-20-2005, 05:55 PM   #3
jbotage9er
Member#: 85193
neat! That makes as much NA power as a c4 vette 5.7L V8
jbotage9er is offline   Reply With Quote
Old 09-20-2005, 06:07 PM   #4
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
The torque curve for the C4 though doesn't drop off to 145 ft-lbs above 5000 rpms...it is relatively stable across the entire rpm band...it is great power for an RS though, really cool if it is an affordable kit.
AntiochCali is offline   Reply With Quote
Old 09-20-2005, 06:15 PM   #5
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Are we looking at the same dyno graph? The scale is 2000 - 7500 RPM. The output is 145 ft-lbs @ 7500 RPM, not 5000.
Old 09-20-2005, 06:19 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
Awesome results Steve. The hard work is paying off!!!!
Jay Storm
Old 09-20-2005, 06:19 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Drop in pistons = $719
Stage 2 SOHC heads = $3244
Gasket kit = $200
Standalone = $1500 (guess)
Injectors & fuel pump = $200 (guess)
Clutch = $325
Total = about $6200
Looks like it'd be fun... perhaps a reflash, and possibly core returns from your stock heads, could make it more affordable.
8Complex is offline   Reply With Quote
Old 09-20-2005, 06:38 PM   #8
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
wow, that's impressive. I never would have guessed
wrxskier18 is offline   Reply With Quote
Old 09-20-2005, 06:57 PM   #9
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
We need to know how this compare to the stock sti on the road. Any vid on the drive to show us that comparison?
west_minist is offline   Reply With Quote
Old 09-20-2005, 06:57 PM   #10
rally_on
Member#: 86849
2005 GMC Savana
white
what year RS?
rally_on is offline   Reply With Quote
Old 09-20-2005, 07:29 PM   #11
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue racecar
Originally Posted by rally_on
what year RS?
2000, it's the same RS on his website.
Patrick L is offline   Reply With Quote
Old 09-20-2005, 07:57 PM   #12
poormansporsche
Member#: 79798
Things to add most likely...
My05 2.5RS intake manni
Custom throttle body
prolly new fuel delivery
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 09-20-2005, 08:05 PM   #13
chanyeehon
Member#: 89848
2005 2.5 RS
aspen white
Gasket kit = $200
Clutch = $325
Total = about $6200
this can be done on a 2005 RS right?
chanyeehon is offline   Reply With Quote
Old 09-20-2005, 08:07 PM   #14
west_minist
Member#: 53451
w/ AVCS Silver
Hey TWE!
You need to get the intake below of the EJ204 and EJ254 from NZ, AUS or JP.
Its a variable intake that works very well over 200chp, 238cnm.
I would love this on my AVCS. Would be interested to see what the results really would be.
Old 09-20-2005, 08:46 PM   #15
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
Cool, havent seen that intake manifold yet...
Old 09-20-2005, 11:42 PM   #16
gpatmac
Member#: 18446
2002 WRX wagon
psm
Exactly what octane?
gpatmac is offline   Reply With Quote
Old 09-21-2005, 12:42 AM   #17
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Originally Posted by mrubino83
So we know that it is a 2.5rs motor, stgII cam, Im gonna say PnP'd heads, new bottom end (any guesses on the C/R?) Im gonna say ( and this is just a wild guess) 11-1, and then the obvious:intake exhaust, header, new/flashed ECU, etc...
not a bad guess if I do say say so myself Nice work guys!!
mrubino83 is offline   Reply With Quote
Old 09-21-2005, 08:23 AM   #18
insaneSTI
Member#: 63953
04 STi
WR Blue
what's it run in the 1/4
insaneSTI is offline   Reply With Quote
Old 09-21-2005, 12:07 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Glad to see some of the details of the build put together. While obviously it takes some real money to make some real power, it also confirms my longheld belief that you can make some pretty serious power with what is essentially a stock bottom end. Our open deck Ej25 blocks are better blocks than most people give them credit for...
Old 09-21-2005, 02:18 PM   #20
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
never thought i would see the day...what octane is this at?
svek is offline   Reply With Quote
Old 09-21-2005, 02:29 PM   #21
wrxsubaru
Member#: 65133
I wonder how much hp would be lost if it were tuned to run on 91 octane? But then i guess we need to know what octane it was tuned on in the first place.
Great job kind of wish there were more NA build ups of subarus.
wrxsubaru is offline   Reply With Quote
Old 09-21-2005, 02:48 PM   #22
rogue
Member#: 7977
100% Abuse
*sports wood*
rogue is offline   Reply With Quote
Old 09-21-2005, 02:57 PM   #23
spongejosh
Member#: 62783
Midnight Black Pearl
i'd rather build up an n/a before doing an entire swap. i'm very interested in details and pricing.
josh
spongejosh is offline   Reply With Quote
Old 09-21-2005, 04:36 PM   #24
Chiketkd
Member#: 71634
In hibernation...
Those are amazing numbers at the crank - 302hp & 276 ft-lbs. Which in a 2.5L engine means 120.8 hp per liter!!!
Imagine if the same results could be gained from doing those same mods to a 3.3L EG33! You'll be psuhing just 2hp shy of 400!!!
Chiketkd is offline   Reply With Quote
Old 09-21-2005, 07:49 PM   #25
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Gasket kit = $200
Clutch = $325
Total = about $6200
Kinda pricey, but not too bad. Especially considering the low price of an RS to begin with. Would love to drive it to see how it compares to a stock STi.
Who's Compass Motorsports 2.5 RS? Flowmastered87GL North West Impreza Club Forum -- NWIC 6 11-18-2013 05:34 PM
1999-2000 2.5 RS - 5 sp xstephenx SCIC Private Classifieds 4 06-02-2010 10:38 PM
99 2.5 RS Silverthorne/coupe/5speed/67,300 $10,500obo speedevangelist Private Vehicle 'For Sale' Classifieds 5 02-05-2004 12:02 PM
whats the fastest NA MY00 2.5 RS? goten2000 Normally Aspirated Powertrain 24 09-02-2003 12:39 PM
2.5 RS NA 12.5 quarter mile christianvwcars Proven Power Bragging 1 01-10-2003 05:19 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
